Apiece of exhaust pipe with a repair washer welded on I have used a plastic cap off a 20ltr tub when 'in the field' , as regards a valve all you need is a 1/2" hole then pull a valve from a tyre into it then you just use a standard tyre inflater .yes i need to figure out a way of pressurising the system ...need a suitable bung with a bolt in valve
!!! I've got a bit of 4" exhaust here, you can have!prob bigger than most exhuahst pipes
Just go to tyre exhaust place you will get the valve and summat there, a fancy tail pipe etc.?
68mm if you can think of anything cheap that size
as I said earlier a screw lid off a 25 ltr container they are 67 mmish just grind off the vertical 'thumb' lumps but leave the bottom 'swage' ring, drill a 1/2 hole pull in a tubeless valve, two minutes and you have it, I have one in my truck I made, in the field, just for this job, and its still used.68mm if you can think of anything cheap that size
