batterys are not that expensive for petrols
Bosch & Varta are the same batteries just to let you know. They're made by Johnson ControlsI find if you buy a good quality battery from a reputable brand like Exide, Bosch or Varta they last mutch longer than cheeper brand you usually find in the local motor factors.
Varta are by far my favourite especially for things that don’t get used often as they seem to keep their charge for a very long time.
Not easily, battery testers check the voltage under load anyway. You need to charge it up before checking. I guess a rough guide would be to check the voltage when the starter is being turned, can't remember how many volts is OK but I guess above 9v.
But it does not show a europe supplier...One of these maybe?
I bought a used one a while ago, seems like a good bit of kit.
My battery has finally given up the Ghost. Its been playing up for 9 months. Little things like leaving the boot open flattened it.@ajlelectronics I'll check it again shortly and see how it reads.
Can anyone suggest a means of testing the starter motor? Someone mentioned that approximately 9v is required to turn the engine over, is that 9v at the battery terminals or somewhere else?
Cheers
