Dave Moore Jag MK2
New Member
- Southern Ireland
I want to plumb in my compressor and create some dog legs as Malcolm Vardy has on the main site. Was going to use copper when I came across this style of fitting. Uses plastic tubing and would be whole lot easier to work with.
https://www.aliexpress.com/item/4000176599447.html?spm=2114.12010612.8148356.1.26da5655A86B1u
Any reason not to ? All the specs say it will handle the pressure.
I currently have 1/4 in fittings. mix of Euro and standard British ( what ever they are technically called).
I am thinking of choosing a 3/8 internal ( 16mm) diameter set up. They do come in 1/2 inch but in the end I need to connect it to the compressor and the water traps , gun etc and from what I can tell 3/8 is a much more common size.
Is 3/8s a big compromise from 1/2 ? I know for HVLP etc 1/4 inch on long runs will be a problem.
Thanks.
Dave
Thanks.
Dave
