soddingtinkerbell
New Member
- Shropshire, UK
Does it belong in something or was it used on its own ? What is a ram and what is a puller ???It's a manual hydraulic press, at a guess. It uses the ram that was common to some of their pullers.
I have obviously entered another universe !No it belongs on something like a pallet and then sent to a place in Surrey
Bob
It is used as it is, OR, the large screwed bit with the bar through it (the ram) can be taken off and used to pull bearings, pulleys, flanges etc. etc off of shafts.
The ram
A bearing puller
A larger version of what your frame assembly is imitating
The ram
A bearing puller
Thank you Seadog for a fantastic reply - now I see it !It is used as it is, OR, the large screwed bit with the bar through it (the ram) can be taken off and used to pull bearings, pulleys, flanges etc. etc off of shafts.
The ram
A bearing puller
Having studied the above - there is a separate item, a long handled pressure gauge which may possibly belong to this, although the paint colour is different so ... I will send a photo of the gauge later and see what you think if that is OK.It is used as it is, OR, the large screwed bit with the bar through it (the ram) can be taken off and used to pull bearings, pulleys, flanges etc. etc off of shafts.
The ram
A bearing puller
Looks complete to me but do post pictures of the other bits could be something else interesting, sounds like a ram or body puller. Like @8ob I'd give it a home.Having studied the above - there is a separate item, a long handled pressure gauge which may possibly belong to this, although the paint colour is different so ... I will send a photo of the gauge later and see what you think if that is OK.
Ah - that makes more sense of what he was doing on that youtube clip ! Is that a test that would be done today or only on older mechanical injectors and are they still about ?
