Try it on both the minimum and maximum settings without changing anything else and see what it does to the weld.The welder has an inductance setting not sure what you use this for?
What sheet is that? How thick? It might be best to start with something cleaner and thicker, learn to weld that and set up the welder before moving onto thin sheet that many find more challenging.
You still appear to be lacking shielding gas on some parts, that or contamination.
