Some guy in Penmaenmawr, North Wales made a device called "Bushmate", was sold thru Land Rover comics. Wasn't too expensive.
M12 x 1.5 is a fine thread. Any reason why it's specced?
I'll quote you, how many do you want?? and any particular material or just bog standard MS
Easier to apply the force required than with a std coarse thread?
You wont get threaded rod in m12 fine,only 1.75mm.Anyone with a lathe and time to spare quote for knocking up item 1, 2 & 3 from this pls...
...i could use threaded rod for the bolt and nut i suppose, unless you feel adventurous.
That looks to be tool for the rear Rose joints on a vectra, if so I did mine with an old cylinder head bolt and various nuts and washers. 3 came out fairly easily, the 4th would not move, so broke the bush apart by pul
