bloobloo
Professional Tinkerer
- Ashton in Makerfield, Wigan UK
Hi all, i have been lucky enough to have been given a burning kit with all hoses, regs arresters and a trolley. currently it has a large propane cylinder (3/4 full) and an empty full size oxy cylinder.
Now then, I am also lucky enough to have a friend who has access to an endless supply of oxygen (she has severe asthma!) she has kindly offered to let me have one of her oxy cylinders and get it refilled when it runs out, but the cylinders are only the same size as diving cylinders.
My question is this, would there be any reason why i couldn't use this type of cylinder if i was to get the appropriate regulator. I have not had chance to look at the cylinder she has offered my as of yet to check what type of fitting it is for the regulator.
I was thinking about buying a plasma cutter until i was given this equipment, as it will probably only get used a couple of times a month and would only be used for light work. can anyone see any problems?
If at all possible i want to avoid the rental option due to not using it enough (and obviously being a tight ****!)
