Hi All,
I know this doesn’t involve fusing bits of metal together but I suspect a few practical types on here could offer some advice.
I need to knock out the side of my glass porch and block up the resulting hole – creating an exterior wall.
I think I understand the process but is anyone able to give me some advice that would be appreciated. So far haven’t found a builder that will commit to the job and also they don’t want to explain what’s involved for obvious reasons.
Some questions …
Either side of the porch panel I am removing is brick work – am I right in assuming I need a wall starter kit for each course to tie the first few runs of the new wall to the existing brickwork?
Is there a set distance the second course needs to be from the first course?
Once I have built the wall to a set height I want to install a window pane – slightly unsure what I need to do at this point as I haven’t properly looked into it.
I have seen what looks like a corrugated roll of wire mesh being laid down in the mortar between brick rows and called a reinforcing strip – what is this and where does it need to be used?
(wall will be 5ft above ground level – so no need for damp course etc from what I understand and will eventually be rendered)
Thanks for the help
James
Some questions …
Thanks for the help
James
