keithski122
I have a builders square which is a clear coated steel, I've noticed its started rusting slightly probably under the coating.Other squares are available and cheap, however most have printed marking unlike this one which has etched markings, with printed after a year or so they wear off.
If I strip the clear off what can I use to coat it with that won't fill the markings, can be done easily at home and cheaply? I can't use oily type coating as its used on fabric, vinyls and leathers.
