Hi Gents, I've just registered to the website but have often read through different postings in my searching answers. So firstly : Thanks to all who are generous with their time and experiences to help us lost souls. You really are a great resource and a credit - in the best spirit of the internet
My primary justification for buying another welder is to make replacement stainless steel pushpit and pulpits for my 1972 sailing boat (a 30ft catamaran). Because these 'safety rails' double up on a catamaran, I estimate it'll cost something like £2,000+ to have these (and stainless rigging fittings I need) made up professionally. So I'm toying with the idea of buying a welder, having the S.S.316 tubes cnc bent to 3d tracings (which I've drawn / 3d modelled in Rhino) and to tack weld them up myself on the job (allowing for deck cambers and all that).
Then, I can drag those 'tacked fabrications' off to a professional, to have the joints neatly and fully welded. By doing all the shaping, cutting and setting up myself I hope to be able to save half the cost.
I used to use a professional mig welder to build multi-tubular car chassis' out of box section - but that was in the late 1970's. Thereafter (redundancy !) I owned a little blue Clarke Gas / gas-less mig (which was probably a 100e ?) Changing the earth lead and using argon-shield bottles, rather than canisters, gave me adequate results for all sorts of around the garage jobs. (the Gas-less gave horrid welds). Except for the occasional wire feed bird's nest caused by the wire burning back up the nozzle I did fine with that - only 30 years ago.!
So, I'm looking to buy a budget mig welder to do neat, strong, one-handed, stainless tacks, powered via a 13amp extension lead in a boat yard, (the machine being lifted up onto the deck of a boat), and then also have a handy (and reliable !) little welder for all those jobs I'd like to do around the garage and in restoring my old Sunbeam m/c's (rusty mudguards and battery box hinges).
Because of the 13amp I thought I'd need to restrict the size of the welder to a 140amp, but then I'll never weld anything thicker than 3mm - so on reduced power would I be OK to get a 150, 160, or 180 ? and benefit from longer duty cycles. Then I'd get wheels and a decent regulator in the price, and possibly better build quality (if that relates to reliability.?
I've never welded Stainless.. Is it as simple as changing the gas type and wire ?
I live (and the boat is) near Ipswich, Suffolk if anyone is local and would like / be generous enough to help me out (when the weather improves !), or indeed if they have a small but reliable machine - surplus to their requirement for sale, and/or can point me to a local and economical supplier for the gases. Did I read the refillable bottles are now available in a portable 2 litre size ?
Sealey are just 20 miles away in Bury St Edmunds and one or two local company sell recon' or factory returned units at a sensible price. Or should I find another Clarke ?
I really would appreciate some pointers before spending what's left of my life's savings..
Big Thanks, Big Pete
I'll look around for that
So the tungsten then is the non-consumable electrode, not the inert gas.. and then you fill the blast hole with the same sort of metal as being welded.. Fountain of all knowledge (aside from this forum) Wiki ; says that inert gas would be argon or helium. Ah ha, clear as a black rat in a cellar.. and why I ask questions !
