i was shortening my ally sump from a ford zetec engine so it would fit my kitcar and i had a bit of trouble and i have had this once befor but not sure what it is
when weld pool forms (yes in ac and clean as a wistle no drafts and good pure argon flow) the arc gets a bit popy and tiny bubles seem to come out of weld pool and if i keep the weld pool still it seems to clean up as long as im not melting fresh metal its ok also get a black scale floating to top of pool
had this trouble once before welding some forged ng6 i thort it was zinc in the alloy could not get a good bond would brake under stress at edge of the weld but the metal is solid when cut
its just tricky to get a nice weld and keep the tunsten clean more power makes it worse as im geting a bigger weld pool and have tryed all sorts of ballance settings but im gussing its just somthing bad material
any ideas pro's
any ideas pro's
Pleanty of sumps out there with that on!!!!
My car had that.... it cracked, caused a mad oil leak and was a pig to remove
