Asda had a good own brand one with temperature control. Great for filling flasks with instant coffee, 60C and ready to drink.£250+ for a Kettle.......
Asda or Tesco......![]()
OK they heat water but they don't have that certain "Je ne sais quoi" that impresses the easily led gentle folk from next door.£250+ for a Kettle.......
Coal Fired ?OK they heat water but they don't have that certain "Je ne sais quoi" that impresses the easily led gentle folk from next door.
Whenever you get experts on the radio or TV talking about the best way to make tea they always say the water should be at 80'C. When you go above that, you make the tea leaves release tannin which gives the tea a comparatively bitter taste. Also, the lecy meter goes round quite a few times getting from 80 to 100'C, and then most kettles will sit and boil the water for a minute or so before the stat eventually switches offAsda had a good own brand one with temperature control. Great for filling flasks with instant coffee, 60C and ready to drink.
.Would agree with that. We keep a manual kettle on the oil fired range. If you need tea you drag it onto the hotplate and within a few minutes its hot enough for tea. Not quite boiling but the tea tastes better for it.Whenever you get experts on the radio or TV talking about the best way to make tea they always say the water should be at 80'C. When you go above that, you make the tea leaves release tannin which gives the tea a comparatively bitter taste. Also, the lecy meter goes round quite a few times getting from 80 to 100'C, and then most kettles will sit and boil the water for a minute or so before the stat eventually switches off.
Well there was no way I was wearing your dress!Good job you had your trousers on.
Look on the bright side.Ah well ******** to it then, cheapo kettle from the local electrical shop it is!
used to repair them at work. it was normaly only the element went on them and a set of new gaskets . power developments made the replacement elements for them think there out of business now though
The only problem we have had is the special nut for the earth connector coming loose every few years, until I made a tool to tighten the special nut properly.used to repair them at work. it was normaly only the element went on them and a set of new gaskets . power developments made the replacement elements for them think there out of business now though
