GraemeVW
- Chesterfield
Brazing is a fantastic process , I have used it in the past on lots of things , you can reinforce thin steel work , bridge gaps and holes , and put things like less than perfect wings onto less than perfect cars with results that are every bit as good as welds in that application , braze tends to spread the load over a larger area which helps things along too , as your not actually melting the parent metal , if it goes wrong you can just melt it off and have another go , braze flows well too , with practice , plus it will skin and you can then go back and lay braze to braze and build up an area or bridge a gap , its a skill well worth developing , and if you have a heat source , either oxy acet or even oxy prop all you need is a few rods and a tin of flux and your off .
many many things use to be brazed together rather than welded , have a play and see how you go.
I've been considering it recently. The odd job that I could have brazed I've silver soldered instead.
I'll look into bottles at some point I'm sure. I have access to a friend's oxy acetylene so can always have a little play with that.
What is REALY like to play with is hardfacing with gas and satellite rods. Looks fun, and I have at least one job that could do with it.
