normspanners
If you cant move it with the hyd' s as standard you are not going to get it out with an air line !! if four pot you have to block the easy pistons and move the tight ones first a bit at a time I use long stud joining nuts with bolts that go inside the hollows of the pistons, that way you can bring them out a little at a time adjusting the nuts and bolts a little bit that YOU decide then can adjust the bolts to hold the pistons just before they pop you can usually tell that it is nearly there as the piston starts to get a little wet as soon as that is seen push that piston back in a fraction with the bolts, then do the easy ones till they are all at the popping point , you should then be able to wobble each out .
I paid about 4.99 for mine and I figured he'd put the decimal point in the wrong place, then I saw the price in the second link I cant believe anyone would buy them at these prices
