I've used air to free pistons loads of times, yes they can go with a bang but a piece of wood and a rag to cover and it will be fine, I'm generally more concerned about the fluid inside going everywhere.
Sorry guys but I am amused by people saying 120psi air will split pistons when a brake system is running 10 times that pressure, 120psi doesn't suddenly become 10000psi because it's in a brake caliper.
Not sure air is going to work if someone has been at it, I refurbed a set of 110 rear calipers recently that looked like they'd been washed up on a beach and air would not touch them and that is the first time I've ever had that happen.
I bought some grease nipple with the correct thread and used a grease gun, popped then out no problem but they went bang even with the grease.
When doing them with I find you soemtime have to work them in and out a few time, so give them some air, if they move but stop then pull the seal back and put some lube in and clean away any loose rust. Then push them back in a little and repeat, if they move then air will normally get them.
If using air then a blow tool with a rubber nozzle is very good as you can get a good seal.
All this get more tricky when you have more than one piston, sometimes you have to pop one piston clean it up and put it back and clamp it. If you use the a piece of wood of the right size you can get the pistons to the point where you can get a pair of grips on them.
