I need to change the inner tie rods on my 2006 E61 5 series.
I am going to do the inner and outer tie rods on both sides even though its just the inner ball joint on the driver side where it connects to the rack that has gone.
The rack is just a stainless ram - it has no flats to support it when disconnecting or tightening the new inner toe rod into the rack. Putting any pipe clamps on the ram will damage it. Do I just tighten the inner nut up and against the rack and let the internals stop it from turning. Its 81ft lb so not silly tight but it just seems counterintuitive not to grip both the nut of the thing you are tightening and the thing you are tightening against to support it. The WSM just says to turn the wheels to retract the rack on the side you are working on.
This guy shows the whole process - he undoes without holding anything and doesnt show doing up.
(see 12:15)
This guy puts mole grips on the rack end but you can see he has scuffed it up and dug into it by doing so -
(see 5:00 and the mess it makes at 7:03)
Do i just nip it up tight with nothing holding the rack ram
