The laquer on my capilers are starting to peel (too much abuse
) and the original Brembo red is now turning pink on the front calipers. I have found a very good how-to guide on refurbing them, but obviously it's recommended to remove all old paint. The guy that wrote the how-to said he blasted his.
Basically, I need to know, what medium would be good to use on brake calipers that will leave a nice smooth finish and just take the paint off, nothing else?
Also, I need a blast gun that can work off my compressor (9.5 CFM free air delivery). I know you usually need BIG CFM for blasting, but because I will only be doing 4 calipers, I should get away with it, shouldn't I?
So, can someone recommend me a blasting gun and medium to go with it?
Cheers!
Cheers!
You have all the handbrake mech/workings to contend with. If you have boggo standard 37mm lucas type ones- swap then for recon ones or buy alloy ones from ralley designs etc.
