Blackening mild steel
  1. GrahamHggins
    GrahamHggins Member
    116
    London, Barnet.
    hi - has anyone used a chemical wipe on in the Uk for blackening steel.
    I believe its called black oxide or etching or something like that.
    Just like to buy a product on net.
    Thanks
    Graham (Ireland)
  2. Have a look for gun bluing or barrel blue, although it's called blue if you leave it on long enough it goes black.
  3. GrahamHggins
    GrahamHggins Member
    116
    London, Barnet.
  4. Screwdriver
    Screwdriver Member
    4,880
    UK London
  5. GrahamHggins
    GrahamHggins Member
    116
    London, Barnet.
    Yes, they look nice. Was it steel or aluminium..
  6. Screwdriver
    Screwdriver Member
    4,880
    UK London
    Cut and paste from another forum....
    If I leave those steel parts bare, they will rust in no time. So I blackened them.
    [​IMG]
    Takes no time at all
    [​IMG]
    tada
    [​IMG]
    Very happy with the result. Just a question of discovering how robust it might be...
    S.
  7. Kent
    Kent Member
    10,002
    Bowland, Lanacshire,UK
    Cold blue is not very hard wearing at all. If it's worth enough you could find out which gunsmith in your area has blind tanks?
    What is the part and what does it do? there are other ways - some better than traditional blueing
  8. Screwdriver
    Screwdriver Member
    4,880
    UK London
    By sheer coincidence I was mesmerised by this vid of a blueing tray.
    julianthegypsy and WorkshopChris like this.
  9. Nick67GT
    Nick67GT Member
    397
    Glos UK
    If you look in Machineries Handbook, there is a whole section on how to colour metals:
    Whether or not the chemicals are available or not I don't know.
    Mine is the 20th edition by the way.....
  10. ChrisJ
    ChrisJ Member
    895
    Tamworth, Staffs
    I can remember in school metalwork in the mid 1970's we made some simple nameplates with our names stamped in with letter punches, the finish on it was done by heating the steel evenly, to just before it got cherry red so it was blue, and then quenching in black dirty engine oil, if memory serves this wasn't a bad looking finish.
    RonnieM and colnerov like this.
  11. clift_d
    clift_d Member
    454
    Hackney innit (UK)
    ChrisJ likes this.
  12. colnerov
    colnerov Member
    3,099
    Nr Gatwick UK
    Hi, That's what I've done in the past.
    Colin
    hunter27 likes this.
  13. The_Yellow_Ardvark
    The_Yellow_Ardvark If in doubt ask. Same rules for everyone
    10,369
    UK
    Still do that myself.
    All that stuff is a mild solution of Copper sulphate. Easy to make.
    But needs a finish like wax to protect it.
    ChrisJ likes this.
  14. ChrisJ
    ChrisJ Member
    895
    Tamworth, Staffs
    I would like to try this on some of my sculptures, would I be correct in buying Copper Sulphate Pentahydrate granules from say Ebay?, and then mixing them into hot water till the solution will not dilute any more of the granules?
    Jonathan Webb likes this.
  15. The_Yellow_Ardvark
    10,369
    UK
    @ChrisJ
    Buy some copper sulphate from the Bay of Fleas.
    Warm water, add a table spoon at a time.
    Test and cleaned metal.
    If no reaction add more.
    Until you get the finish you want.
    Label container.
    Use to blacken or as a weed killer. Or as a base to copper plate.
    I used it on a chess set I made. Blackened the parts, did not like it.
    So went and copper plated.
    slim_boy_fat, Screwdriver and ChrisJ like this.
  16. ChrisJ
    ChrisJ Member
    895
    Tamworth, Staffs
    Thanks :thumbup:
  17. There is a better process than the copper solutions but its more expensive. I use a metalblak kit which comes with alkaline degreaser, blacking solution and dewatering oil. I derusted some car parts and blamed them and they seem ok so far. Cost about 30 pounds I think,
  18. GrahamHggins
    GrahamHggins Member
    116
    London, Barnet.
    It would be for benches and tables - mild steel and to cover welds.
    So I guess a wipe on is what I'm after.
  19. nickk Forum Supporter
    1,796
    Hay-on-wye
    when the solution is mixed whats the shelf life?
  20. sardine
    sardine Member
    2,845
    Buckinghamshire
    Posh Shotgun barrels are "blacked" in a tank of boiling caustic soda based chemical solution, i dont know whats in it but it stings ! small parts are blued by burnishing them and heating to get the colour, it goes light straw, dark straw, blue, purple, the skill is catching the exact point the colour changes, and quenching in neatsfoot oil.
    The blacking is not rust proof in any way, if you leave them wet they will rust overnight. Military weapons are phosphated for a tough finish.
    Harry m likes this.
Advertisements
