I don't think a biscuit jointer is the tool for that - you'd have to make the groove as a series of 'stabs'. I don't think it's possible [advisable] to slide the cutter along an edge whilst it is engaged.That's another purpose I've been thinking it'll be useful for; Groove/slot cutting. Say, for example, slots in drawer sides for a drawer bottom. Simple, quick method. Easier than dragging the table saw out.
A slotting cutter on a router, however, would work a treat (especially on a router table).
Colour me astonishedSo, should I put this in the "Today I ordered...." thread, else in here?![]()
Colour me astonished![]()
DON'T BUY A BISCUIT JOINTER UNLESS IT'S THIS ONE!
I'd be looking to do that on a router table,That's another purpose I've been thinking it'll be useful for; Groove/slot cutting. Say, for example, slots in drawer sides for a drawer bottom. Simple, quick method. Easier than dragging the table saw out.
You can do it but the real question is why would you? Invest the money in a really good router table.... Unless you already have oneIt is, however, simply a small wood blade on a fancy angle grinder, with an adjustable fence. There's no reason it shouldn't be upto that task.
The table saw is another tool which could readily achieve that task, but that means me oiking it out of the workshop for one small task.
You can do a floating floor for a wooden box as well as a fixed lid top for it . I was given a box of somethign the lid would not open as over the years it expanded with moisture. Four weeks in the airing cupboard the box dried out beautifully & has a load of router bits in it . . I think whoever made the box used a router for the sliding top & bottom but forgot to adjust the channel width to allow for bit of expansion according the to the local weather conditions .That's another purpose I've been thinking it'll be useful for; Groove/slot cutting. Say, for example, slots in drawer sides for a drawer bottom. Simple, quick method. Easier than dragging the table saw out.
My router table is a 900x 110 x 10mm ( £90 inc vat in 2008) thick sheet of mild steel , the 55mm router hole I cut slightly to the left & low off the center , counter sunk the screw mounting holes & turned a blanking plate to fill the hole when the router is dropped down & not in use. as the bench doubles as a heavy work bench with a gert big 10 inch Woden securely bolted on it at the front left corner and and as my welding table .You can do it but the real question is why would you? Invest the money in a really good router table.... Unless you already have one
Bought one donkeys years ago with a large bag of biscuits, used it twice, can't actually find a use for it as a diy'er, , it seems to be good idea at the time but just another unused tool.How useful are they in reality? I'm tempted to get one, but I'm still on the fence. Worthwhile addition to the tool collection or not?
I know it's one of those types of question. Some may find them invaluable, some likely won't.
Elu DS140. Had one, would never get any other one.
It's so versatile, it'll cut the bottom off doors with ease, and that's probably all you'll ever use it for!
But get one, and then get a Domino too, it'll be really useful too. I'd like a Domino, but I'd have another DS140, just because.
But seriously, check out the Elu. It's an old machine, but you can find them in pristine condition, because no one uses a biscuit jointer.
Easy fix, no excuse.Wrong colour.
