Yer too slow, watched it hours agoHere's how I fit liners, can be a bit tricky with thin soft wire on a long gun, so these tips should help you avoid a few pitfalls.
Nice. Any chance you could repeat this in a new thread so that we have a chance of finding it when needed?Right, a few on how to fit the liner.
It's supplied long and you cut it down to length. It's important to take a Stanley knife and chamfer the end so that the liner stands a chance of making it all the way to the end of the conduit and into its receptacle at the end of the torch as there is always a joint where the flexible part of the torch stops and then torch body starts.
Then once the liner is all the way home, put the collet on, then the o ring and liner nut. Don't use the a spanner on the nut or you can crush the liner causing wire jams.
Next the o ring
Then we can fit the torch and cut the liner to exact length as close to the drive rolls as possible.
Cut the liner to length and then we can fit the liner protection tube which helps support the liner and protect it from damage in the event of a feed jam.
Again, the tubes are supplied long and need cutting down to length. Like so...
