Hi guys
thought l would start a build thread after a bit of prompting by DrNik today
l have wanted to build a big fifth wheel trailer like this for a long time and have steadily been collecting
parts and working out the details
clearly this isent a 5 minute job and will take a couple of years but space is becoming available in one of the barns so l might get to melt some metal soon, there are many options decisions and choices to be made along the way but most l have at least thought about if not made a decision, not least what am l going to tow it with, weight is going to be around 5 tons
any way the first plan was to use 100mm x 50mm box as the main chassis rails with a step up at the front into the bed room above the pin, for axles l dug out a pair of transit twin wheel axles with the intention of lopping the diff out of each one and sleeving the casing that way l could make them any width
l wanted, l would have those massive big drum brakes on each of the 4 wheels, hand brakes already built in and l could run 4 or 8 wheels as they are twin wheel axles, plus l have some new 16" transit wheels and tyres that are 6 ply result, what a saving trailer axles are pricy in the 5 ton range,
but that was just plan A we are somewhere near plan M now lol, turns out you cant use hydraulic brakes on a trailer over 3.5 tons they need to be air or electric pah.
this is the nearest thing l can find on the net to what l want to build, only with more slide outs,
slide outs are a bit of a double edged sword really they defiantly give you more room and create an impression of airiness but you need a set of seals to keep the rain out in the in position and the out position but it was the mechanism for the slide outs that gave me most headaches especially when they are opposite each other,
