Wow! That looks nice ... so is it like for like then eg for 38mm into a 38mm joint do you use a 38mm hole saw with coolant obv ?Depends how many you are planning to do, for small quantities a hole saw is as good a method as any,
Great thanks ..If you're going to do it by hand here's the dimensions to make a template to wrap around the pipe to mark it.
Blocklayer.com has a tube notching sectionGreat thanks ..
Is that off an app or a website looks very useful .. I’ve about ten in total to do
It's a phone app called flat pattern. If you have ten to do and have access to a pillar drill then I'd recommend using a holesaw like Paul. has.Great thanks ..
Just used it, very good TY..
Do you mean what size hole do you need to put in the pipe that the notched pipe fits up to?Just used it, very good TY..
So for the piece it’s joining too would this be a 38mm hole req, cut with a hole saw ?
Yes, I’m guessing that would be the internal dia about 35mm ?Do you mean what size hole do you need to put in the pipe that the notched pipe fits up to?
Yeah 35mm holesaw is right to drill the hole. I can email you the templates for the notched pipe and the hole in dxf form if you want.Yes, I’m guessing that would be the internal dia about 35mm ?
Please mte thanks ...Yeah 35mm holesaw is right to drill the hole. I can email you the templates for the notched pipe and the hole in dxf form if you want.
I've just emailed it onto you,
I down loaded the app flat bottom end but can’t get it to do what I need, there seems to be no alternatives from the patterns they give you, prob me the issue mindIf there's any problems with it let me know and I can send it again
