Older cylinders may be thick enough... But many modern ones are very thin and flimsy. Depends what you are making.just use an old hw cylinder theres loads getting scrapped and combi boilers fitted in place
must be new as its for manufacture of a product
In my dreams!Will we be seeing you on Dragons' Den?![]()
Thats about the size of the flat blank we start withEdit, just seen you require 160x90mm. is that the finished profile, or do you do more work to the blank?
If you could that would be goodWhen we did the copper roofs on the two extensions I bought a 50m roll of 0.7mm copper 600mm wide that was sold by weight, I can most probably find the company I bought it from if you want.
