Haha. Yep. Would prefer it if this thread didnt take that turnIt’s a whole subject on its own.
the metal place built a big press thing for squishing down tanks ,, it was made from jcb scale rams and old factory I beams ,,, tough bit of kit ,,,I'd have / had zero issue with fitting a used plastic bunded tank.
I mean it's either been run into with a forklift or it hasn't. It's pretty obvious either way.
Thread deviation on this forum ….. Nah that never happens!Haha. Yep. Would prefer it if this thread didnt take that turn
Best keep quiet about it thenBear in mind there are regulations regarding clearances between oil tanks and air vents, non fire rated eaves, boundaries, and the edge of the base it’s sat on (to name a few). Building regs document J covers them. If you change size and/or shape of tank an installation that was compliant might not be anymore. I have a different view on this to some as I am an ex oftec engineer. Most tanks I came across didn’t comply with regs.
Well no not really... If you buy an old tank and it fails and you have a non compliant installation it could be a bit problematic. Hopefully that’ll never happen but thought it was worth sharing. You can guarantee that insurance companies will look for any reason to not pay out. Also more regs now on bunded and non bunded tank locations etc etc. It’s becoming much more regulated.Best keep quiet about it then
Oh yes ^^ always forget farceache as i dont have an account and it wont let you search easily without logging in now. Will get the other half to look.
Rich be careful about single skinned tanks if you even appear to be a farm.Whats the advantage/rules on bunded tanks? Just that its contained if it leaks?
I think the rules changed notably for diesel tanks where they had to be bunded by April last year or the year before (about the time I moved back to Wales). A lot of the oil companies around us were getting shirty if you still had a single skinned tank even if it wasn't for diesel.
They almost refused to fill my parents red diesel tank but because the driver was there and Mum managed to convince him to be a nice bloke (I think a bacon sarnie was involved) he did actually fill it up but said the next guy probably wouldn't.
If you're 100% private then they don't have an issue but farms have had a clamp down.
Was discussing this today, apparently a heat pump, (?) In English. You drill down into the earth, sink some pipes, and you can have a reversible hot/cold system.
Pompe a chaleur in French.
Is recommended nowadays, economy wise.
