I feel bad that annotations, was autospelled to animations as that took this way ofcourse.
Also you cant have welding drawings with out annotations
Let the dimensions, on standard views, specific section views, part sections, state what you want.This is fascinating, it really is. Thanks so much for this. I now see / understand the point ‘telling a story on a drawing’. I guess ‘less is more’ is the idea?
As I mentioned above, I got away for long time with a line in the "Notes" in the corner of the drawing . . . "fully welded construction" . . .I feel bad that annotations, was autospelled to animations as that took this way ofcourse.
Engineer has to know what they are talking about - and I see a lot of drawings where they don't. Fillet sizes that are ridiculous for the thickness of material. Continuous welds when intermittant would be better, even if only from a point of view of less distortion.I would not be happy having steels welded by anyone if my engineer has not specified the weld requirements.
I would not leave it to most site welders to advice on.
Then we had a "proper" welder join us . . . he took one look, and said "What I am supposed to do, glue it?" . . .
I do still add notes to the effect that neat welds are acceptable un-ground - one of the guys at one of our suppliers used to work with me at another company - and he seemed to have a limitless supply of sanding discs - everything got a coarse disc run over it on a 9" grinder . . . made making a painted machine look good next to impossible.
But I also think a neat weld, left alone if it's not bothering anyone, looks so much better than one sort of ground back - and hopefully if the supplier doesn't have to spend time doing it, I get it cheaper/quicker.
Apologies, I meant a stop-start, not a gap between welds (a stop-start is a requirement of most awarding bodies)The isometric with the weld symbols posted above has several stop/start annotations - the "2x75(50)" - two welds, 75mm long, with a 50mm gap
I have pictures of the rest of the manual if you want themDont you use phase testing nowadays? this is one of the exercises from the EMFEC course left over from my teaching days which was derived from and equivalent to City and Guilds, this is a first year practical test for MMA welding complete with material thicknesses and weld details all in mm, I have pictures of the rest of the manual if you want them, did have all the books up to year five covering all the processes but unfortunately were lost in a house move some years ago
Does this include all weld details and symbols etc?I am quite late to this thread, but we are building something that may be of interest here.
See video
Happy to answer any questions!
We're also looking for additional beta testers for this summer, if interested, please join the waitlist here.
I often have to print out stuff for a fabrication shop , I've never seen weld specs on engineer's calcs or the accompanying drawings. Is that a thing that should always be on them?Engineer has to know what they are talking about - and I see a lot of drawings where they don't. Fillet sizes that are ridiculous for the thickness of material. Continuous welds when intermittant would be better, even if only from a point of view of less distortion.
This is for machinery, rather than structural though.
Engineer should specify minimum weld sizes yes. Even if it’s just a blanket ‘All welds 6mm fillet UNO’.I often have to print out stuff for a fabrication shop , I've never seen weld specs on engineer's calcs or the accompanying drawings. Is that a thing that should always be on them?
Stu
I will have a look through old ones to see if it's on the joint detail sheets.Engineer should specify minimum weld sizes yes. Even if it’s just a blanket ‘All welds 6mm fillet UNO’.
Currently working on itDoes this include all weld details and symbols etc?
