No mate, otherwise as you bend in towards each other they hit each other and prevent you further bending due to it still being attached on the outside. Cut the outside then bend inwards that opens up the split then weld it. Also remember to bend further as warren says since you must allow for the contraction of the weld on coolingjust to clarify do u cut the inside
its bad enough bending 3/8 x 3inch in a vice with a big hammer and oxy propane try heating that lot to cherry red and keeping it hotI'd use oxy/propane and a big hammer.
is there no engineering place, or a handy lad with a bit of gear about him that could bend it for you?For an upcoming project I will need to bend some 14mm thick mild steel plate, also other sizes but 14mm will be the thickest.
What sort of capacity shop press would I need to bend a piece of 14mm plate, 130mm wide?
yrs ago i made a press out of a porta power unit, it will bend 70x10 cold but if you had the way of heating the 14mm up with oxy acet then something like that would bend it no bother if you had it good and hot.
BOC being the gas crowd and not some crowd with the initials of BOC ?It's doable, with oxy acet and a cutting torch I have bent plenty of 100 x 10 plates. It'll just take a little patience.
Yes, try BOC - phone the head office and tell them you're a hobbiest and see what price you can get out of them.
if it is the gas crowd, what kind of services do they offer over there other than new gear?
or maybe your saying to go to boc and get the oxy acet kit off them, which looking back id say is what you meant but i took it up wrong, my bad.
Ok. I have propane but no oxygen, good excuse to get an oxy propane set up though. What is a good brand for such a setup? I have a BOC account so could try them for an oxy bottle
