BrokenBiker
- Newport, South Wales
Asking advice before I whirl into making things harder than they need to be...
My little 4 inch vice locked up a while back trying to press a bit of steel into some ali...
Its been very stiff ever since so now my new bench is in place and 6" vice firmly affixed im stripping the 4"
Threads on the shaft and nut are all fine, and when the vice is apart they run beautifully together, but i have noticed the face on the bottom of the nut, that bolts into the vice body, is bent. Ill be honest, ive never had a vice apart and was expecting this to just be cast in and then Drilled and tapped, but thankfully its removable.
As confident as I am that I could remake this quite easilly, I want to try and fix it first but would you say this bend is the issue and causing the threads to bind? Or is it somehow meant to be bent as some sort of preload? The face it bolts to is flatter than a flat thing with the exception of the paint on it
I was prepared to bin the vice if it was properly fubar'd but apart from this bend i cant find anything suspect in there
Also, I assume this is cast iron, partly due to its age (atleast 30 years old) and partly because of what it is, but i will spark test in a min...ideas on repair? Heat and hammer or just flat it off with the belt grinder?
This will become a blacksmith vice when repaired and only really used for twisting, bending and clamping for grinding/filing so hasn't gotta be perfect, just half decent to use
