wellingtonrock
wannabe welding wizard
Hi.
I've got a little hobby MIG welder - Telwin summat'r'other. Not terribly nice, wire's always live so it's gotta be handled a bit carefully. Anyway, my questions may be more generally applicable, but I don't know.
First, can someone tell me please, whether the gas flows only when the wire's being fed, or is it flowing all the time the valve is open?
Another one, elsewhere on this forum was some mention of orifices for regulating gas flow. As a newbie, how do I know what size orifice I've got, where is it fitted, and where do I go to get the correct size one? The reason I ask is that the gauge is showing 40 lpm, and I've read here that I should be aiming for 10 or so.
Thanks in advance for your help.
cheers
denis
cheers
denis
hi there denis firstly the gas should shut off when the trigger is closed if yours is leaking gas out it would need replaceing with a new one in the torch secondley as for the flow rate your right at about 10lpm what sort of reg is it i presume its adustable try cranking it right down and the setting it to 10 lpm on the gage it might be that the flow rate of gas is to high and leaking through the gas valve as for replacement parts pm weldequip on here he maybe able to help you out ian
