This is what has been keeping me busy for a few days welding on a k reg Nissan Serena.
N/S INNER SILL REAR (O/S WAS THE SAME)
N/S INNER SILL CENTER REAR (O/S WAS THE SAME)
N/S INNER SILL CENTER FRONT (O/S WAS THE SAME)
N/S INNER SILL FRONT (O/S WAS THE SAME)
N/S INNER WING 1
N/S INNER WING 2
N/S REAR OUT RIGGER 1 (O/S WAS WORSE)
O/S INNER WING 1
O/S INNER WING 2
Will take some picks of the outer sill that I had to make as you cant get pattern parts & the dealer wanted £600 per side plus VAT (car only worth about £7-800). Other things the car needed for the MOT were O/S lower ball joint / wishbone, 2 front metal break pipes, adjust handbreak on one side. I recon about £5-600 at a garage. Cost me £80 for wishbone £43 for 8' by 4' sheet of steel (used half of it) £5 for pipes, elec for welding welding gas & wire, grinding disks (2) cutting disks (3) Total about £150.
Garage was well pleased with the welding & wanted me to take on all the stuff they dont do (they only do small welding jobs).
Justme
N/S INNER WING 1
N/S INNER WING 2
O/S INNER WING 1
O/S INNER WING 2
Justme
