Hi All,
Been asked to make up a part for a grass roller which has thrown a bearing, and then sheared the mounting off the A frame. Making up the mounting is ok, as there is another one to copy. There is also a bearing on the other side to take measurements from. However, I am more used to nice smooth bearings with sensible sizes. This one sits in a groove on an "axle" internally and then fits into a cup attached to the A frame on the outside
Do I use the diameter of the groove as the internal diameter, or the axle? - the difference is 3.75mm in diameter, so definitely going to make a difference. The groove is not as wide as the bearing, so it isn't for the whole thing to sit into.
I also don't really know if it is going to be a metric or imperial bearing! It has an 89.75mm OD, 20mm width, and either 59.75mm or 63.5mm ID (the oddness of the numbers makes me think it is probably imperial...)
Any help really appreciated - one of those "do you want me to sort out a new bearing whilst I am at it?" comments that I should stop myself from saying - although I like to think it is good customer service, and it will be nice, as the thing can be put back together at the end of my job.
