MattF
- South Yorkshire
Paul is after a thrust bearing though I think.
Never noticed that line in the original post 'til you mentioned it.
Looking on tractor forums, other people have struggled to find the right bearing but no one has come back to say how/if they sorted it.
Are you not a member of a club or such? A chap I know used to have a Fordson, I believe. Can ask him if he's any idea if you could mention exactly which part it is.
I am.
I think i have a non-standard leveling box on there. I've just found the original part drawing and its nothing like what i have. It looks like the bearing Pete has linked to on ebay would fit the 'original' Dexta bit of kit.
Mine is marked 'enfo' so IS original Fordson kit...i have found this a few times with my tractor that it has oddball bits on it that are not referenced on forums/manuals/original details.
It's probably a non genuine part anyway if it doesn't match the book so just order a complete unit from sparex or vapormatic! I'd guess it would be easily under £100 so is it worth ******* about doing it up.....
Real helpful CoNot designed for radial load either, just thrust. I suspect that the cause of spinning on the shaft is the balls rusting in the races and the races rusting in the outer shell causing the rotating element to seize.
Here's a taper bearing that would fit if your shaft was perfect:
http://simplybearings.co.uk/shop/p4...+Set+0.75x1.625x0.4687+inch/product_info.html
