I have a spare 12v battery that I occasionally remember to trickle charge,last done 2 weeks ago,it shows 13.1v,and then I noticed the water level was a smidge below the top of the plates,though they were still wet. Is this still useable? Thanks.
13.1v is a typical float charge voltage.I have a spare 12v battery that I occasionally remember to trickle charge,last done 2 weeks ago,it shows 13.1v,and then I noticed the water level was a smidge below the top of the plates,though they were still wet. Is this still useable? Thanks.
Got a link for the sealey one by any chance?Voltage checks on batteries do not ensure their capability to work. It is the amperage that does the work so a load test is the only way to prove the batteries capability. Any good garage should be happy to oblige or you can buy a tester for not a lot of money. Ebay have a Sealey drop tester new at £36.99 free postage. This is the one I use and its good. Easy to read and accurate.
Couldn't agree more, we have them waste of time. Cranking voltage with lights on is far more useful.The cheap Sealey tester (and the various other badged versions) only tickle any reasonable sized battery. You're lucky if it can pull 50A.
We had one at work, and the cables aren't even single core, they're twin core to give the impression they're heavier copper!
Agree again!Ideally now you'd use a capacitive discharge tester (aka a modern digital tester), as they are far more accurate than a ye olde drop tester.
