Craig-SM
- Heckmondwike
That's the one I have with the 5ah high output battery, maybe I'm being thick here but what setting is the most powerful, #3 or the one with the bolt on it?
I had it set to #3 and it wouldn't shift a Mazda 3 wheel nut that had been Kwik-fitted on!
3 should be the most powerful, the 4th is basically a nut spinner that cuts off at very low torque.
Setting 2 removes wheel nuts off the Shogun with ease, same setting will remove drive shaft nuts too. 3 should remove the wheel nut with ease.
