If you parallel those leisure batteries with a good battery and stick the charger on them you may find the good battery brings the voltage up enought for the charger to start. I done this a few time with completely dead batteries and it works.
So I still have a large number of batteries waiting for me to get around to sorting. Fix or scrap. I picked up a very nice looking bike battery. Had been sitting in a shed since new, flat as a sheet of paper 0.4V, dry as a bone and covered in a thick layer of lead sulphate. The electrolyte is long gone but recieved wisdom tells me it might be possible to dissolve the sulphate back into lead and acid.
I bought a cheapo battery reconditioning device for twenty quid. Got nothing to lose really and plenty of batteries to sort, including the two monsters mentioned above. I started with the dead bike battery.
It's being fed by a big dumb old 12V charger which is my go-to device. Nothing smart about it. It will sit there happily delivering 14V at up to 8A all day every day, unlike my other "smart" chargers which as often as not fail to do anything at all or just switch off and let the batteries die.
Anyhow, I wasn't expecting much from this first test having only hooked it up last night. But incredibly, after refilling with distilled water (not deionised), it appears to be working. The battery is now showing 10V so there's definitely something happening.
Apparently a high voltage high frequency "jolt" can start the process for lead sulphate crystals to dissolve back into solution where (one assumes) they dump their lead back onto the plates and sulphuric acid goes back into solution. I am guessing but I suspect if the crystals fall off the plates into the bottom of the cell, they can no longer experience the electric charge they need to dissolve so I might need to top up with a bit of acid..
It might take a few days or maybe a couple of days for this small battery but well worth it. If I only restore one battery back to life it will have paid for itself, I have dozens of them...
Would you have a link for where to purchase the £20 unit please?
Think I may have accidentally bought one! got a pile of iffy batteries so its worth a goJust found it, something else to buy
Bats fetch strong money, around £500 per tonne.
Most of our batteries are for electric fencing so dont need to be top notch, just a few days longer life would be niceYou might get the voltage up to a good level but the capacity will still be massively reduced.
A full tank sound good till you find out its only 1/2 litre tank.
Recycle them all & use the money to buy one new one.
I've had a de-sulfator for about 10 years now and I'm convinced they work. That is, provided the main problem with the battery is sulfation, and not the other issues which can kill a battery.
The picture in post 64 shows you charging the battery at the same time your separate pulsator is in use. As soon as the battery stores any charge, I like to run the pusator without the charger, as some/much of the pulse may be lost in to the charger and not go on to the battery. So I do alternative cycles of charging and pulsation. My pulsator produces a spike of about 16V (possibly more), but the duration of each spike is probably down in the microsecond range; it can barely be seen on my old 20MHz oscilloscope. the spike frequency is about 15kHz. I think you may need longer that 2 to 3 days to get the best results.
There's video on YouTube of the Indians reconditioning battery's. Putting new fabric in. It's the fabric that gets cruded and "shorts" as it were. Hooking them upto a welder and over cooking them can cook the crud off.
I think it's easier just weighing off the lead of it to pay for 1/3 of a new one and save yourself the time tbh.
Probably only worth the prattling about on expensive leasure battery's.
I use a gunson rapidstart. Small and can jumpstart. Couldn't recommend it enough.
I've read so much manure about batteries by home taught egg spurts I could frtytilize a fo=ie=ld with i5t and still have enough for my farmer mate down the road .Google tells me that's more of a cleaner than desulphating agent.
Might be something you'd stick in a battery to prevent sulphation but I don't think you can recover a battery with it.
