Hudmut
- Derby
Iv just ordered a Baileigh tube notcher as well as a few meters of 25x1.5 steel tube.
Now that I have a Lorch T220 tig I want to try and use the features as in pulse and back ground some thing or the other and the tea maker function. But the manual is of no use to me at all it tells me what things are but not what they do and how to use them.
As a base setting I was going to wade in at 45amps 1.6 filler and tungsten but what about on pulse. I do know I should step my amps up but by what factor 25% may be and then my down side by the same factor with a pulse of say 1.5 seconds what about this back ground thing what's that doing why would I use it and how much.
Then what about the rest of the setting's because I'm a bit up set with the answer of just run factory setting you will be fine just twick them that's not really what I just paid for. I have a foot pedal all so and Iv worked out some things like pulse does not work with that why is that and what about the up and down slope should I use this when on pipe work to help in some way ?
Any base setting will help with a under standing of why I need then and what they do the pipe is not going to be any thing just yet just stick time as my next plan is to make a air ride trolley to go behind my traction engine running go kart slicks with water cannon.
Thanks for any help
Thanks for any help
