i hope so i havn't opened mine yet but was looking at these
http://cgi.ebay.co.uk/5-3-METAL-CUT...Home_Garden_PowerTools_SM&hash=item4157acd194
Just bought 25 off amazon for £12.55 free delivery.
With the 3" cut off tool are the discs standard? as you only get 1 in the box.
Presumably because if oil was added to the lubricator container then it would be introduced to the air fed to the spray gun.
Cheers for the heads up steveo ,, never thought of thatyou might want to remove the plastic shield and check the head nuts etc , i did when mine was new and they werent all that tight
If you REALLY want to use it on your spray gun, I think the lubricator can be removed from the regulator. I bought one the other day but I have only had a quick glance at it, so I am not completely sure if it can be done, but I have a feeling that you would get away with it.
I am assuming that there is some sort of O ring seal where the 2 units are joined together, and I am also assuming that there will be a suitable thread to connect the quick release couplings.
If I remember, I'll pull mine apart tonight and let you know!
Also got some halogen floodlights which (even though the instructions say not to) are going in the shed for worklights.
