Erie Fred
- Erie, Pa USofA
Before I would go adjusting, I would get a new fresh blade, as the blade you have been using might be dull (from rubbing & not cutting)Thanks folks, turns out all it needed was tha weight adjusted. Twist the pressure off the spring!
Still a mill off square, is that acceptable or could it be adjusted too? Cheers
and may cut off to one side.
After adjusting the vice square & such with a new blade, you can put the old one back on and see if it's still usable.
- joking aside thanks for that I have a few to do
