Wallace
- Staines, Middlesex, England.
That's a logical progression for the 6x4 saw, a much better and easier way of cutting angles.
Interesting Paul, that first one is just like the one I bought off Gavin, I like the coolent tank idea.
If you're considering horizontal bandsaws and unattended cuts, it would be quite remiss of one not to put the slightly alternative suggestion of an old Rapidor out there too.![]()
I don't think it is the same one Paul, I think Gavin said it was owned by a double glazing firm hense the spare wood cutting blade, it is just the same model and a similar age / condition.I did sell it to somebody on here.
Can't remember his name but I keep thinking American cars for some reason. V8 Pontiac or summitorother.
The big one was a bargain. It had a rattle and the bloke only had it up for £250.
Turned out to be a key fell out of the gearbox pulley. Cost me 50p to fix.
As an aside, a cheap saw will cut well if it has a quality blade, M42 bi-metal for example.
Paul G
I will have a go at making a coolent tank for it, even tray to collect the steel sawdust would be a start.![]()
. I guess apart from careful setting up it would benefit from a bi-metal blade and I need to find a space for it?I guess apart from careful setting up it would benefit from a bi-metal blade and I need to find a space for it?
Good choice I've put a bi metal blade on mine and I plan to make a few more modifications but it only took a few minutes of tweaking to get it cutting straight. I noticed in your OP that you mentioned cutting sheet too so just a suggestion I found I had to put a 24 tpi blade on for sheet as the standard 14tpi blade tended to snatch and ended up loosing some teethNorlander
I ended up buying you first option as I had a VAT free certificate from MM and so save around £50. I have not taken it out of the box yet but it is heavy - 62kg to lift into the back of the car - getting old. I guess apart from careful setting up it would benefit from a bi-metal blade and I need to find a space for it?
I found that out very quickley, won't do it again.............. until the next time that is............... If you use the standard wheels and handle on the stand supplied make sure the bow is in the down position when you move it as it wants to tip over as you lift it.![]()
You can but the wood fibres mixed with coolent and or cutting fluid used when cutting metal don't half make a mess in all the guide rollers. I spent quite a while cleaning up mine, it came with a spare wood cutting blade but I do not think it will be used for wood whilst I own it.Just as an aside if I use the correct blade can I cut wood with a metal cutting saw (blade speed?) I do quite a bit of hobby work with r/c aircraft.
