P Po chung New Member Messages 5 Location United states of America, ca 90720 Apr 25, 2019 #1 I recently bought a used Astro Power MIG 130 every time I plug it in it trips the breaker please help
rtbcomp Moderator Messages 18,574 Location Sheffield UK Apr 25, 2019 #2 Welcome to the forum. Does it trip when you plug in, switch on at the mains or when you pull the trigger? Is it an MCB that trips (over current) or an RCD (earth fault)?
P Po chung New Member Messages 5 Location United states of America, ca 90720 Apr 25, 2019 #3 When I plug into the outlet
P Po chung New Member Messages 5 Location United states of America, ca 90720 Apr 25, 2019 #4 The heat selector switch is difficult to turn, this is what I noticed
P Po chung New Member Messages 5 Location United states of America, ca 90720 Apr 25, 2019 #5 I don't know what MCB & RCD means?
P Po chung New Member Messages 5 Location United states of America, ca 90720 Apr 25, 2019 #6 Is it possible that the heat selector is fault6?
rtbcomp Moderator Messages 18,574 Location Sheffield UK Apr 25, 2019 #7 Any chance of a photo of the front panel of the machine, and also the rear? Just to clarify what controls it has as it's not a make I've heard of. MCB - is a minature circuit breaker, they replace the fuses in modern consumer units (distribution boards). RCD - is a residual current device, it trips out if there's a leak to earth somewhere, I assume you have them in the USA.
Rig Pig Member Messages 3,742 Location Narrwich! U.K. Apr 25, 2019 #8 I see you are in America, is the welder 110V or 220V if it's a 220V set it won't work on 110V
Sean Another 602 fan Messages 1,460 Apr 25, 2019 #9 weldingweb is mainly USA based so there may be more chance of someone knowing what you are talking about ( heat selector?) as well as being more familiar with the likely electric supply you will have and your machine https://weldingweb.com/forum.php
