540itouring
Hi , just to ask if you can give me the approx gas flow rate i would need to weld 0.9 mm floor plate in a car . I was going to try the small 110 litre bottles to start with as i only need to weld small plates where i have cut the old rust away. Can the flow rate be set approx with the small regulator or must you have a flow meter to set this up. I do have a good regulator and flow meter but this fits a large bottle and as i do not have space for a large bottle i plan to try the small bottle. I have seen cheap flow meter for £9.99 and wonder if they are ment for small bottles and if so are they any good ? The wire i will be using is 0.8mm. i have a new ESAB Caddy C200i
Any help on flow rates for Argon / CO2 and regulator + flowmeter please ?
With many thanks in advance.
