BrokenBiker
- Newport, South Wales
If this was your first ever attempt at welding what reference do you have to say the wire was terrible?I found the Clarke 0.9mm wire it comes with to be awful. This little set was my first welder to see if I could learn at all - & the Clarke wire is a hindrance as its so rubbish.
The Wire type I switched was I think made by SIP, and the wire type was E71-TGS (Halfords stocked it) in 0.8mm.
The 0.8mm went through the machine as-is, with the 0.9mm tip with no issues I noted.
Also, yes 0.8mm wire will go through a 0.9mm tip...you will probably also get away with 0.8 through a 1mm tip, I dont actually know what tip I have in my mig, it might actually be a 1mm as the last lot of 0.9mm wire i had kept jamming so I put a bigger tip in, dont think I changed it back but its had 4kg of 0.8 through it since.
What do your welds look like with the sip wire?
