then u would need a lager blastpot and jet to make full use of itWhat size of compressor have you got? To run a 3mm blast nozzle you need at least a 14cfm air supply & it will be very slow to clean a chassis (think about colouring it in with a large marker!)
Ideally you need a road compressor which you could hire in for major projects.
put a blastpot with 3mm jet on a 90cfm compressor and it hardly gets of tick over
theres a lot of waste when your running a pot at well under its full power. they really need running at 90psi constant 80 percent air and 20 pecent grit to get the cutting velocityI read the sand blasting article in the help section of this website. The author says he got through 350 kg of media to blast a small car. That's 14 bags, seems a lot.
never used soda its expensive but don't do panels with grit or fine sand even at lower pressures . it lets the stress out of the metal and warps them. bonnets are the worstThe pot arrived and assembles quickly.
I read somewhere that they need to be converted for use with soda, is that right? I've got body panels to do and worried about using grit.
Someone said they need careful setting up. What needs setting up though?
its called powerwash afterwards and a bloody good blow heaterI run a blasting company in barry and blast car all the time, i would love to see how they get all the wet media out of a car as it get everywhere and how they stop them from rusting instantly, and how they clean up the mess it leaves
The cavities on my car are quite simple, so would I not be able to just hose out the media? The car is totally stripped down, so the interior can all be hosed.
As for stopping it rusting, I was going to dry it using a power drier and then put it in my insulated garage with a space heater and industrial dehumidifier.
The power drier is actually just a dog drier I use on my German shepherd, basically a powerful blower that also gives out some heat.
i am sure you could wash it out, i find blasted metal can go rusty over night without any water present so the thought of wet blasting cars has me baffled the media goes everywhere and as above the slurry it would create would be a nigtmare to clean up can see the council being happy with it just being washed down the drains. just my 2p worth not seen it done yet we media blast complete cars dry with no panel warping just has to be done right, and even then it can take hours to get all the media back out and we have a massive industrial hover
