Hello,
You can tell im new to this; Making up some rocksliders for the land rover...they're made from 40x80x4mm box section and there are plates that ive bolted to the chassis (which ive strengthened) made from 5mm plate.
Where these plates meet the box section I plan to arc weld them....im just a little concerned about the strength of the joint, considering that it'll take lots of weight when the car is jacked from under here.
Ive got 3.2mm rods, and I reckon around 120amps would do? The bits I welded on the chassis had full penetration (you could see the shape of the weld on the other side) so the welds were ok I think..
Have attached a drawing (looking down from the top at the joint) with the weld high-lighted in red..
Are these welds strong enough?! You can tell im a little paranoid!
biosbill
biosbill
