Gingle
We are all in the same boat
- England uk Cambridge
Arc welding rod .So when I weld thick bolts nuts so on,the 2.00mm rod melts to a puddle but does not stick to the bolts,it leaves a black weld but does not weld.It just breaks away .I'm welding at 60amps .Do in need to use a 2.5mm at higher amps .,the thing is when I use the mig welder,flux wire it seems to weld better,but I do like my arc welder.
