Fishaholic001
New Member
- Clermont fl
I appreciate you input. I did order all 4 caps I will replace them all. If the caps were already loaded to full or 3/4 possibly the extra surge pushed them beyond what they could reserve and it had to go somewhere. I’m thinking what happened was you know how when you shut it down it continues to run for a few before it shuts down- I’m thinking that he did not let it shut down completely and it didn’t have time to disconnect itself from the 110 and 220 tried to go thru the 110 circuit side There's a reasonable chance it might still work if you replace the blown cap(s). If it was switched to 120V operation but connected to 240V, it's not a great surprise that it vented the caps in this way. However, I assume it didn't get as far as actually activating the arc as it would still have been initialising, in which case that part of the machine may well still be functional.
When being tested for UL, CSA, CE etc certification, this kind of explosive venting isn't considered acceptable, so normally there would be some sort of voltage limiting device across the bus caps, such as VDRs or gas discharge devices which would cause the input fuse to blow first. The Arc Captain products look pretty well designed internally (I have their MIG and TIG machines, which I've done non destructive teardowns on), so I'm a bit disappointed (or is that simply naive?) to see this kind of failure.
