normspanners
Has anybody had any experience of these little beasts my nephew has one,he bought it but would not start off the key, it would crank fine but would not fire all you needed to do was walk it 3mtrs and drop the clutch and it was away, hot or cold. It has had a new piston and pot btw by the previous owner I had a quick look and IMO there was no real spark you could just see it in the dark, so a new stator was ordered and fitted with no difference BTW there is no adjustment for the stator it just fits .
During fitment of the stator it was noticed the mains where VERY worn, so engine stripped and new mains and seals to keep the flywheel in closer tolerance to the stator . Made No diff.
So new CDI ordered and fitted, still not good will start off the key sometimes but there is still in my view a VERY weak spark, and the engine bogs out easily, BUT then when it goes IT GOES it picks up and flies!! we have tried removing the oil pump blanking the input to the crankcase and running on premix. Crankcase has been smoke tested, it has a 95 main jet when 80 is standard but still looks slightly weak mixture, I managed to get it to run better, in desperation by putting several layers of denim over the air filter. PS reed is good and carb been cleaned twice. It has an arrow after market expansion exhaust btw.
ANYBODY?
ANYBODY?
