Hi, I have Selemix 7-413 epoxy here. I have to lay some down tonight and I've never sprayed it before so I had a look at the tech sheet.
It's totally mixed up. It's giving totally different mix ratios volume vs weight. It also says it should be sprayed minimum 3bar.
Has anyone here used it before and if so could you point me in the right direction regards
Epoxy to Activator ratio
Thinners %
Recommended Psi for Devilbiss FLG5 - 1.8mm setup
Thanks in advance
Thinners %
Thanks in advance
