rikrobson
- Perth, Scotland
was hoping to avoid buying another wheel as ive painted this one
You'll have had plenty of practive painting then
I used that method years ago on a 69 bonnie and it worked perfectly, so I'll second Mr Shox on that one.Use the axle and some spacers, with a dog driven off a spoke. that way it will run true to the axis
if you are going to try something like this you will need something very rigid that will stay true to the surface you want to skim and ideally the full width of it, also do it with very light passes so that you don't remove more material then is necassaryive got a die grinder, might try to rig something to hold it onto spindle
it is a very real possibility that corrosion is to blame, it is also very possible depending on how oval it is that any machining will go through the steel liner rendering it scrapAs I've already said distortion COULD be due to corrosion between the steel liner and the alloy wheel. This needs to be carefully checked before any machining.
Think about it - what has actually caused something that was originally perfect to become distorted ? Steel brake drum lining don't normally become distorted for no reasonSourcing a better wheel, and repainting, gets my vote as action to take.
was hoping to avoid buying another wheel as ive painted this one (right ball ache to mask up) and had new bearings and new tyre fitted
The inserts are Cast Iron, hence (As I said in my previous post) they are known to crack.
