I wonder if you could get .6mm wire into spray transfer on 3mm?
Has anyone spray transfered 3mm steel? Id have thought it was very difficult. Certainly would speed my job up.
Spray transfer,28+v, on 3mm plate, not at all!!
3mm plate, 6/7/8 mm fillet leg???
Probable suckback on the reverse side of the plate;
Distortion like it's going out of fashion:
1mm wire on 3mm plate is not an issue whatsoever; penetration should not prove to be problematic on these lighter sections,
Dip transfer, play with the volts/wire speed and Tune the spatter out
Question for you one millists, do the amp/volts and wire speed associated with using 1mm wire on 3mm not impact on penetration. Got this thing in my head that it’s just blasting wire/weld at the job at such a rate that penetration must be compromised. Personal choice on 3mm and under is .6 in as close to spray transfer as possible, it all seems a lot slower and easier to control for me than the bigger set with .8.
Bob
