In theory the bread dissolves, I’d do it on cold water without a thought. I’d freeze it but it means gutting another room to get far enough away.I wouldn't leave anything in there permanently if that's what you're asking. If you can't pick up a can of freezer, use a bung and pull it out after soldering (long bit of string etc.). if you're soldering a right angle that gets a bit hairy. You need some freezer spray.
OTOH you could always cut the tricky part off and use a straight connector to rejoin.
Thanks. Actually I thought I had, but turns out I’d forgotten one (massive) rad.If you can't vac it out there is too much in the system to for anything to work. Drain down properly, opening all the air vents on the rads. Starting at the top
